-   -   Coil ground (https://www.offshoreonly.com/forums/do-yourself-boating-budget/278740-coil-ground.html)
Den P 06-16-2012 08:00 AM
Coil ground
Hi.. Just replaced the coil in the 454, and checked for 12 v between the + and -, and had nothing. I have 12 v from the + to the manifold tho.. Normal? No cont between the - post and manifold with the key on, but it's there with the key off.. Is this right? Thanks!
F-2 Speedy 06-16-2012 08:22 AM
its fine , the - side of the coil is not a true refference point for ground.
Den P 06-16-2012 08:33 AM
Thanks!
FIXX 06-16-2012 01:41 PM
fixx
Originally Posted by Den P (Post 3710615)
Thanks!
this will tell you if its working ok...turn on the ignition on,,remove the coil wire from the dist,stick a screwdriver into the center of the coil wire and have a friend that knows nothing about cars or boats hold on to the metal part of the screwdriver,now touch the negitive side of the coil with a ground wire and if he gets knocked on his ass you know its working...:thankyouthankyou::lolhit:
compedgemarine 06-16-2012 02:50 PM
remind me to never help you with anything:lolhit:
