Bravo 1 stuck in forward. any suggestions >
Old 07-12-2012 | 05:50 PM
Default Bravo 1 stuck in forward. any suggestions
My outdrive on my starboard motor is stuck in forward but works fine in forward. Checked my cable and it works perfect all the way into drive. Pulled outdrive any suggestions what may have happened? Never had a drive apart before. I consider myself pretty good and wondering if I should tackle this one or send it to marina?
overdooinit is offline
Old 07-13-2012 | 02:02 AM
Pull the back cap off and see if you can get the linkage to move.
Griff is offline
Old 07-14-2012 | 11:39 PM
Randy Nielsen's Avatar
Default +1
you will have to turn the input shaft while moving the bellcrank if its stuck.
Randy Nielsen is offline
Old 07-15-2012 | 07:58 AM
CRG
same deal last july 4th, cone clutch was stuck.
CRG is offline
Old 07-15-2012 | 10:16 AM
mrquad1's Avatar
x-2 on cone clutch,time for tear down
mrquad1 is offline
