SEA PUMP drive ratio question >
Old 08-14-2012 | 10:12 PM
Default SEA PUMP drive ratio question
I recently repowed the boat from gen 5 to gen 6 big blocks. My question is becasue I have a different crank balancer I had to buy a new crank pulley. The pulley had a larger diameter puller for the sea pump. That being said this will make the sea pump spin faster. Can anyone see any harm in doing this? I am kind of worried at high rpm that it may not be able to suck enough water from stock Bravo pickup? went from 4 inch diameter to 6 inch diameter pulley. Any input from experts? Also anyone know where I can get a BBC waterpump that will host a 8.5 inch crank fluid balancer. Stock waterpump will not fit. I know L88 corvette 427 big block waterpump from the 1960's will work but do I have another choice if anyone knows?
overdooinit is offline
Old 08-14-2012 | 10:38 PM
I believe at high RPM, high boat speed, the sea pump itself is getting alot of help from "force" feeding from the drive/pickup. The pump itself probably works harder pumping at idle than it does at high speed.
As for your circulating pump issue, I cant be of help. You can always eliminate it and run a crossover setup if all else fails.
MILD THUNDER is offline
Old 08-15-2012 | 08:32 AM
I do have a set of crank driven waterpumps and crossover shafts. Maybe it would be easier to run it that way. Thanks for the heads up.
Old 08-15-2012 | 08:40 AM
The sea pump is all you need.
Old 08-15-2012 | 10:29 AM
I have a crossover setup with the stainless steel seawater pump and highly recommend it, engine runs right at thermostat temp.
ThisIsLivin is offline
Old 08-15-2012 | 11:19 AM
How are you guys routing your hoses from sea pump using crossovers? I may just take this route as it is a much cleaner look.
