blown 350 wont pull over 4000rpm >
Old 09-24-2012 | 05:17 PM
Originally Posted by mrfixxall
dont know if its the same gut i talked to a few weeks ago but he said he had the plugs at .040..
plugs gaped at. 035
michaelb63 is offline
Old 09-24-2012 | 05:21 PM
Originally Posted by Bowtiepower00
What Ignition? Stock HEI? Might need an ignition upgrade, cam appears on the small side, which would explain a lot, but definately throw a WB O2 on 'er, and keep that thing rich or you're going to be melting pistons...
How does she act when the power falls off? Any breaking up or misfiring? Or just feels soft when the power builds? Could be spark or fuel, double check both before changing anything internal...
I agree with staying Hyd Roller, but not sure if the hot cam is the best choice with boost.... If everything else checks out (spark, air, fuel) add more cam...
Good luck...
pulls strongup to 4000 just hits a wall,no no breaking up or,misfires
Old 09-24-2012 | 05:22 PM
Good luck...
pulls strong up to 4000 just hits a wall,no no breaking up or,misfires thunderbolt IV ignition 8 psi fuel pressure at idel to wot.
Old 09-25-2012 | 01:30 AM
I hate to tell you this, but the entire build is all wrong for reliable marine engine. The pistons are not what you want for a blower engine. The hyper pistons are marginal for a performance engine, the comp ratio is about the max you would want for a naturally aspirated engine and 9.5 is certainly too high for a blower engine. A forged crank would be much better. The cam is small, but is being cheated by using 1.6 rockers instead of standard 1.5's.
It really sounds like this was pieced together with a bunch of leftover parts.
Griff is offline
Old 09-25-2012 | 08:20 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Truth be told .
the deep is offline
Old 09-25-2012 | 01:44 PM
Prop down to a 19" prop and see if the same thing happens. 15" diameter 22" pitch is a lot for a small block. A prop change is an easy non-invasive test.
Trash is offline
Old 10-02-2012 | 04:49 PM
does the same thing with a 13.750x23 3 blade the 350 mag would spin it at 5200 rpm . but seeing that boat season is pretty much done here .going to go ahead and pull the motor out and reuild it this winter. ditch the hyper pistons, go with flat top forged pistons ,any suggestions on cam size while i got it tore down ?
Old 10-03-2012 | 12:11 PM
I find it hard to believe a stock 350 Mag would pull a 23" prop through a 1.5 drive to 5200 RPM. I have yet to see that done in any SBC except in a very light boat. That equates to a 67 mph with 11-12% slip on a stock 350 Mag. I just don't see that happening.
The numbers are off somewhere.
Trash is offline
Old 10-03-2012 | 01:36 PM
Default fixx
really? i swing a 26'' prop to 6200 with a 355 through a old volvo penta drive with a 1.62 ratio..mild small block..
FIXX is offline
Old 10-05-2012 | 03:00 AM
Blower or N/A?
Trash is offline
