does 502 have guardian mode
i have 1997 502 mpi 24 foot baha. does it have guardian mode. if it does, can you clear guardian mode by using led at diagnostic connector & moving throttle. i dont have a clear understanding of guardian mode. thanks for info.
clearing
Originally Posted by troyc565
(Post 3813727)
502 MPI's do not have a guardian mode. If your engine is a 1997, then it should be a 502EFI with a VST system. No guardian mode either.
Originally Posted by Griff
(Post 3814247)
FWIW Low oil pressure engine run rpm threshold 400 RPM Low oil pressure engine run time threshold 10 Sec Low water flow engine run rpm threshold 2000 RPM Low water flow engine run time threshold 10 Sec The time variable is what is allowed before RPM reduction is activated These variables will reduce RPM |
My 96 would go in "safe mode" and wouldn't rev over 3000 rpm...it was a 502 mpi
| All times are GMT -5. The time now is 10:17 AM. |
