# dyno #s sbc
Old 01-07-2013 | 05:55 AM
Originally Posted by Andrew 19
hp @5700 tq@4700
@3600 h=295 t=430
What are good a/f #s ??. Thanks for the input.
P.T.L.
Rory
You have in my opinion built a near perfect SBC for a boat. I have twins with slightly lower numbers that I am putting in my 5600# Formula as I write this...can't wait to get it in the water.
Question...do you know what your oil temp was during testing? Are you planning on running coolers? Just curious.
sprink58 is offline
Old 01-07-2013 | 10:16 PM
What was your compression ratio?
Trash is offline
Old 01-10-2013 | 09:08 PM
#s
Men; Thanks for all the input. My a/f #s are
from9.2 -10.1 up to 5800. These are w/old
metering blocks. Going to Pensacola fri to pick
a little mouse stroker. Hope to update entire project with pics later:
PTL
Rory
Andrew 19 is offline
Old 01-11-2013 | 12:17 AM
AFRs of 9.2 - 10.1? Were your eyes watering from the fumes?
Keep us updated. Project sounds neat.
Trash is offline
Old 01-21-2013 | 08:47 PM
Smile Pro Systems
Just a little bit to clear up previous post;
My engine top end designer, Bob Madara and my builder,
Donnie Culbertson of Speed Unlimited Pensacola Fl are both
Pro Systems dealers in good standing. After starting pulls it was noted a/f r incorrect. Donnie called Patrick and a complete FIX was discussed. Replacement parts were shipped
within 48 hrs. Now that is service I am 100% satisfied
with my new stroker and Pro Systems carb.
P.T.L.
Rory
Old 01-22-2013 | 09:42 PM
I would have guessed at least 450 h.p. Sounds like a good combination. Eager to hear how it pushes your boat.
Wes Burmark is offline
Old 01-24-2013 | 09:05 PM
Default Edit
One little tidbit I forgot to mention. Bolted to azz end of
crank is a Fidanza aluminum wheel. Talk about throttle response,
can you say zip........zip ?? Hope it performs as stated. Thanks again.
P.T.L.
Rory
Old 01-27-2013 | 06:17 AM
Congrats! I've been very happy with Bob's combo on my Challenger.
Ryan00TJ is offline
Old 10-26-2013 | 05:47 AM
Thanks for posting your info...... I would think you left some power on the table running so rich.. Sounds like you have a real nice and well thought out combo of parts! Excellent! TBF
tpabayflyer is offline
Old 10-29-2013 | 06:22 PM
Sprink 58 asked about oil temperatures. I have twin tube (one for engine oil, the other for PS fluid) 2" dia. 9" coolers on each stock 6.2. This keeps the temps to the edge of what Merc recommends at WOT. If you are not running a good sized cooler on a stroker smallblock (IMHO) you should.
