Yet Another Carb Question
Old 01-04-2013 | 07:21 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Have you ever given this guy a thought : http://nickersonperformance.com/images/topdesign_01.jpg He has built two for me and i couldn't be more pleased . Go Stage V for your engine .
the deep is offline
Old 01-09-2013 | 02:01 PM
I've pulled the carb and will go through it with a fine tooth comb now that I have it on the bench. I will pull the secondary PV. I think my lean miss may be just my PV starving for fuel.
ThisIsLivin is offline
Old 01-11-2013 | 11:32 AM
blue thunder's Avatar
It sounds to me like the secondary float level is set too low.
blue thunder is offline
Old 01-11-2013 | 12:33 PM
I actually have it set a little on the high side. I think the fact that the boat pulls so hard was leaning out the secondary power valve. I'm planning on removing the secondary PV. Of course a bigger prop would help that problem too.
Old 01-11-2013 | 03:01 PM
Did you check the float level in the water or on the trailer?
Old 01-12-2013 | 01:15 PM
need to put a vacume gauge on it and see what vac you are pulling at different RPM's, you may be getting to point you are closing the power valves even at WOT
ezstriper is offline
Old 01-14-2013 | 07:31 AM
I've set the float levels in the water at 1/4 up on the site glass. I do have a vacuum gauge and I pull 10" at idle in neutral, 5"-6" in gear, 7"-8" at cruise, and it stays 0" at WOT. I have a very custom flame arrestor to make sure I have good flow. I have the K&N 4"x14" USCG certified element, with a velocity stack style base and a top that helps direct flow into the carb.
