-   -   CP Performance Stainless Steel Sea Pump (https://www.offshoreonly.com/forums/do-yourself-boating-budget/291710-cp-performance-stainless-steel-sea-pump.html)
86Capri 03-07-2013 08:31 PM
Originally Posted by GAZ (Post 3881585)
Hey 86 Capri,
Looks Great! Where did you get your S/S lines and fittings ? Especially the large diameter water lines coming into the raw water pump.
Thanks GAZ
All the lines I had made local at a hydraulic line place called tompkins. cp sells a 1" adapter for the water inlet. So they are 1" stainless from the back up to the pump and to the cooler.
EdNewman 04-29-2013 08:09 PM
Just installing them. Very nice machining, but I'm swapping out the bolts for some the correct length. The ones that come with it are too long and too short.
EdNewman 05-06-2013 10:15 AM
Proper bolts are 5x 3-1/4" long. Also, the pump ends up being longer so it looks like I am going to use a 90 degree fitting for the water output that runs to the fuel cooler on my 525EFI. I will cut the half of the horsehose bend off the hose.
