Alpine radio help
Old 03-08-2013 | 06:15 PM
Default Alpine radio help
I just installed an alpine cda-9886m head unit along with alpines mc20 commander remote. The radio works fine, the remote powers up, and displays information, but it will not control the radio. It seems like the commander is frozen? Does any one have this set up? Or tips to get it to work?
86242ls is offline
Old 03-08-2013 | 08:41 PM
BDiggity's Avatar
when you paired the mc20 to the 9886m, did you have the head unit set to FM source? Its step 4 of the procedure, seems like that would be step 1. after pairing did you then power off the mc20 & then back on again?
I have 2 mc remotes plus a key fob paired to my 9886m. all can control all sources, although ipod control is difficult.
BDiggity is offline
Old 03-08-2013 | 09:31 PM
I tried to pair it with the radio on, and once with the radio switch to iPod mode with an iPhone connected. Initially when everything powered up I was getting radio display on the commander, but couldn't use any of the functions no volume or seek etc.
When I installed the antenna portion for the commander to the back of the radio I used a ground, 12v source and the 10 pin connector that plugs into the radio, their were a couple other connections that were their that I didn't use could this be the problem? The instructions are kind of vague for the commander!!!
86242ls is offline
Old 03-09-2013 | 08:15 AM
I had this set up in my old SeaRay. It was a royal PITA to get set up and never really worked that well. Big fail for Alpine. If I remember correctly, there are two 10 pin connectors on the head unit. Make sure the 8mm plug is plugged in the head unit and try the other 10 pin connector. Make sure you reset the MC20 and use the new pairing procedure each time you try the other connector. You can also call the Alpine tech line.
jamontes is offline
Old 03-09-2013 | 08:26 AM
I will take another look when I get back out by the boat the finish up the stereo install. Hopefully I can resolve this issue!
86242ls is offline
Old 03-10-2013 | 08:17 AM
BDiggity's Avatar
Should have a 3.5mm & a 10pin connected to the 9886m from the mc20's add on module. the 3.5mm is actually the steering wheel control so if that's not plugged in, maybe that's why I cant actually control the unit.
I definitely had to read the directions 10x before I started. good luck.
BDiggity is offline
Old 03-10-2013 | 02:15 PM
Well, I for sure do not have the little steering wheel plug attached, so hopefully that will do the trick!!!!
86242ls is offline
Old 03-15-2013 | 08:00 AM
Well after plugging in the steering wheel control jack and powering up the head unit, I cycled thru a couple radio stations and was able to add the commander. Everything is now working like it should!!!!
86242ls is offline
