-   -   Cam Selection (https://www.offshoreonly.com/forums/do-yourself-boating-budget/292747-cam-selection.html)
dozer 03-09-2013 01:21 PM
Cam Selection
I am trying to find out why someone would use a regular solid lifter flat tappet cam on a 600hp 496 stroker, rather than a roller set up.
1BIGJIM 03-11-2013 08:24 PM
Thats old school, I have built several strokers, buy a custom cam designed for your engine from RMBUILDER. It's worth the extra money. IMO :cool:
bcfountain 03-12-2013 08:28 AM
in a single word.....cost.flat-tapplet cam and lifters=250.00 roller cam/good lifters=800.00.when your doing 2-3 motors that little extra $$ helps.a roller would be better though.
1BIGJIM 03-13-2013 09:01 PM
nobody else is chiming in soooo.
If you truely thing you are going 600Hp with a flat tappet cam you are going to need the the best parts money can buy. Unless you are going to strap a blower to it, you are going to have to spin it past the limits of a Bravo drive.
To make 600HP with a 496, the exhaust system will cost way more than a cam and lifters.
There I said it.:grinser010:
winterfunguy 03-15-2013 06:28 PM
One thing to remember when running a flat tappet cam is that the engine oil MUST contain zinc. Most oils today do not have zinc as flat tappets have become a thing of the past. Shell Rotella still has a high zinc content as do most "break in" oils, there are many Zinc additaves to add to your oil as well. No Zinc + Flat tappet cam = severe and RAPID lobe wear.
dozer 03-16-2013 12:25 PM
Thanks for all of your inputs
donzi matt 03-16-2013 05:21 PM
Rotella does NOT have adequate zinc for a flat tappet cam. They reformulated a year or two ago. I was running Mobil 1 20/50 V-twin in my 420's before I pulled them down. Now they are getting roller cams. Between the available flat tappet cores, the available flat tappet lifters, and the poor oil choices, the odds are stacked against a flat tappet being durable.
Sunrocket24 03-16-2013 05:41 PM
I have a flat tappet cam in my engine and zinc is a must. I buy the expensive Brad Penn racing oil with high zinc content cost me about $100 per oil change. I did flat tappet to save money during that build. My next engine will have a custom RMBuilder roller cam in it. I will get my money back buy not having expensive oil changes.
FIXX 03-16-2013 06:08 PM
fixx
one,,cheaper,two less moving parts which makes it more reliable.and three if you use crower cam saver lifters then you really dont need to run zinc additives..
Flyin-Bryan 03-16-2013 06:12 PM
Good info on the lifters.
Sunrocket24 03-16-2013 06:14 PM
Great point! Wish I would have know about those Crower cam savers!
