Self tune mefi burn, am I crazy?
Hey thanks for the tips.
I have a stock mefi3 system, and stock merc HEI ignition....no plans to change.
The ECU is stock, and I will save the files as you noted. Finding someone to provide a "close" tune to adjust is near impossible, mainly because they will lock it so that their hard work can not be pirated.
The hardest part that I see ahead of me is aligning the ARF readings with the ecu data log. From what I can tell with the stuff I planned to purchase so far it would be manual, I need to do more research because I would like the two to work in the same log.
This AFR meter logs data. Not sure if it logs it over rpm or not but if so that would be the ticket IMO.
If it were me would can all the merc crap, run a laptop programable on your boat and be done with all this sending back and forth B/S...its a short in the dark and usually not very close to where it should be....I run megasquirt with my own EFI setup with a procharger....
I had gone the FAST efi setup. I got the starting tune from another member. I set it up where the efi could richen the AFR by 25% if the O2 thought it was too lean and only lean out by 2%. In the beginning I had a friend drive the boat while I made changes to get close. Once I was close I would just run a log and then go back to and update. I had lots of help from other OSO members as I was trying to get the idle perfect.
I was having a problem one time and was able to talk to a fast engineer. He was great help and got me past my problem.
Would I do it over again? Hell yea!
I say go for it 4bus. I don't know how much the Mefiburn is but I would look at what the cost difference to go with a different ECU system. Holley, Big Stuff, FAST or Megasquirt. Then you can always tune your new upgrades.
