-   -   Distributor assembly options for 6.2? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/293334-distributor-assembly-options-6-2-a.html)
rgrgoog 03-23-2013 12:38 PM
Summit has some for under 200
http://www.summitracing.com/parts/du...make/chevrolet
boatnt 03-23-2013 09:32 PM
when they brake on me i always use a J nut on the bottom and leave it alone..holds the cap on just fine,,,
Captain YARRR 03-24-2013 03:24 AM
Now that is damn brilliant! I think that is worth a shot for sure.
boatnt 03-24-2013 11:00 AM
had a few Suburbans and Astro vans at work that broke a ear while changing the cap and I always used a J nut and never had a issue..
Captain YARRR 03-24-2013 06:53 PM
I went to Home Depot and couldn't find any J nuts deep enough to grab the bottom lip. Where did you get yours? In the mean time I strapped it down with three cable ties and it seems to be working well until I find a better solution. Not moving at all.
The problem now is that the engine will rev smoothly until about 3800 RPM, it will not rev past there and then throw an alarm on the way back to idle. Not going any further. I've heard an IAC on the way out will do that. Thoughts? I checked the pintle on the IAC and it moves freely.
Here's a video:
http://www.youtube.com/watch?v=ssobQB48e1U
lakematdude 03-25-2013 01:27 AM
Here's a video:
If you're not in the water, in gear & under load then that reving the engine to only 3800 is perfectly normal. You're hitting mercruisers guardian mode designed for protecting the engine from you doing just that. Please, do yourself a favor, stop revving the engine in neutral.:eek:
You really shouldn't rev over 1800 rpm max. FYI, while on the engine flushing device (ear muffs) the recommended engine RPM is 1300 rpm.;)
Andrew 19 03-25-2013 04:17 AM
Capt.
Same thing happened to me several years back. I used the zip tie method also.
Mine worked fine for years. If no misfire, I don't believe cap to be an issue
w/low rpm s. P.T.L. Rory
boatnt 03-25-2013 06:56 AM
Here's a video:
speaker J nuts work pretty good
Captain YARRR 03-25-2013 07:48 AM
It was in the water :)
TWIN-SPINS 03-25-2013 08:10 AM
if it was in neuyral,and in the water, it will still go into guardian( over rev )code,,,looks like you where still tied to the dock on your video,,, the shift sensor lets the computer knows it,s in gear and then will not allow the over rev code
