-   -   which heads ??? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/294517-heads.html)
ThisIsLivin 05-06-2013 06:47 PM
Originally Posted by mike tkach (Post 3904553)
if it is in the budget i think some afr 290 oval port aluminum heads would work good for that application,call bob madera and see what he suggests.
The 290's will give you much better velocity than the 088's and better flow overall. You should still call Bob Madera, why do want to screw with a bunch of jokers who could be jerking your chain when you can talk to one of the best and get a real education to boot. The reason you aren't getting any more responses is that you already got your answer.
egbolt 05-28-2013 08:24 PM
I second call Bob his the best, help me i lot on my build this past winter
496 stroker with m3sc procharger its like a timex
anthonystempak 05-28-2013 11:39 PM
I think its those old 088's aswell in a ported form that flow a bit. But iron eagles
Get the flow data on those
