502 EFI Water in stainless manifold
Has anybody experienced water intrusion into a Merc 502 Gen 6,
415HP EFI engine with Stainless Marine Manifolds and Risers? Thanks |
Originally Posted by bob53magnum
(Post 3940907)
It appears to be about 15 years old. Jerry at stainless and everybody else I have talked to says they have never experienced a failure with these manifolds. I thought it would be in the riser, but cannot find a leak with hot water.
(Post 3945350)
If you have thru hull exhaust and your internal flappers are burned out, it may be coming from there. External flappers are not 100% effective. You really need both.
Chris |
you definitely have reversion with any motor that has an over lapping valve events. T he key is minimizing its effects. The S/m manifold with the short riser is no better and probably a little worse (as would most aftermarket manifolds w/ the short stainless riser) than the factory manifolds. The overlap in a stock 502 mag should be pretty minimal though. Do you idle for long periods of time thru no wake zones etc? Try to keep the revs up a little more and/or rev the motor up in neutral from time to time... if water reversion is actually the problem.
Thanks for the reply. I still have not found the "smoking gun" and HOPE it is just reversion. I tested the manifold and sent the riser to SM for testing. I will try and pressurize the block and heads this weekend. If evverything tests good, I will put everything back together and start it up and see what happens.
| All times are GMT -5. The time now is 01:56 AM. |
