Old sender doesn't run new gauge >
Old 06-30-2013 | 12:16 PM
Default Old sender doesn't run new gauge
These are things you learn as you modernize an old boat. I put all new gauges in my '79 Formula Liberator ...including fuel. I noticed that the fuel gauge wouldn't work. Some investigation revealed that the original sending unit's ohm impedance doesn't match the new gauge...so I get to install a new sending unit!!
Live and learn.
sprink58 is offline
Old 06-30-2013 | 01:36 PM
I'm right there with ya. In all my new gauges, I got new oil pressure and water temp sending units. My fuel however works but is wrong. When empty the gauge is 3/4 and as I fill it it just goes to pegged full. Gotta figure it out. Lol
Crude Intentions is offline
Old 06-30-2013 | 04:56 PM
The one I need is $70 at Boat Owners Warehouse. I'm going to get one this week...I can't stant not knowing how much fuel I have...sort of like SCUBA with no air gauge !!!
sprink58 is offline
Old 07-01-2013 | 12:24 AM
I'm just fortunate I know where empty is. Don't ask me how I found out. But I know for sure now!! Lol
Old 07-01-2013 | 08:31 AM
I'm in the same "boat". Need to switch out new sending unit for another new sending unit.....
Mr Maine is offline
Old 07-01-2013 | 10:56 PM
Same boat here(not literally same boat) last owner put auto meter pro comp marine gauges in but no new sending units. Temps were off, oil pressure reads backwards, hooked up a manually to determine that, scary times there and fuel always reads full, that's bad. So instead of buying new sending units, I found original gauges. Haven't installed them but will prob do the important ones first like fuel oil and water.
Good luck.
s022mag is offline
