installing K Plane 280's
Old 09-22-2013 | 09:27 PM
Default installing K Plane 280's
How difficult is it to install K Planes in a twin engine boat with engines installed. I almost did this during my re-power.
Well...today I lost a Bennett Sport Tab running in rough seas in the ocean...snatched the hinge plate out and snapped the plastic strut right off....so I am seriously considering it.
sprink58 is offline
Old 09-22-2013 | 10:41 PM
Shouldn't be real hard John. Accessing transom where tabs mount would most difficult.
Crude Intentions is offline
Old 09-22-2013 | 10:44 PM
The tabs itself are not hard to install.....You will need to fill the holes from the bennett tabs and the k-planes need 6 holes plus you will have to mount the trim pumps. If you are installing indicators...1 more for the cable and you have to run 2 cables to the dash. How much space you have inside of the hatch is a different story.
turbo rr is offline
Old 09-23-2013 | 01:25 AM
c_deezy's Avatar
It would suck. Unless you are tiny.
Time-wise it would probably be a wash, whether you pull the engines back out and do things the easy way, or try to squeeze in and out with the engines in the way.
Personally I would pull the engines. Maybe try it with the outside manifolds removed first and see if that gives you enough room to work.
c_deezy is offline
Old 09-23-2013 | 06:32 AM
I am not tiny...6-3 255..LOL. Pulling the outside manifolds may give a smaller person access to do it. Labor wise doing it that way may be the way to go.
If I pull the engines out of this 255 again it will be to put them and the drives in another boat.
sprink58 is offline
Old 09-23-2013 | 11:51 AM
An easier install might be Lenco HD SPort tabs. Dont have to mess with the pumps as they are electric actuated. I have a set on my Velocity 260 and they have as much if not a little more surface area than a 280 K-Plane.
low_psi is offline
Old 09-23-2013 | 12:40 PM
CIG3's Avatar
The Lenco (Heavy Duty) ar ethe way to go. Use all the bennet mounting holes and are Stainless instead of aluminum. Great product.
CIG3 is offline
Old 09-23-2013 | 05:59 PM
That's an idea I had not considered...thanks guys...makes a lot of sense and very easy to install!!
sprink58 is offline
Old 09-24-2013 | 01:57 AM
Seems like the way to go to me!
turbo rr is offline
