Reversion issue 454 mag gen6 >
Old 06-20-2018 | 08:46 AM
  #31
Originally Posted by 232
So here is an update on my reversion issue. what i ended up doing is I went to 16 inch stainless risers which eliminated the silent choice. I then added 3/4 inch water dumps off of each manifold which goes through the transom. I installed silicone exhaust hoses and put a piece of 4 inch stainless tubing inside the exhaust hose from the riser to the exhaust tip for added security against burn through since im not running as much water through the exhaust riser and into the exhaust stream. next was the drew marine exhaust tips that were fitted with GGB 5.5 inch inserts. I also installed a ball valve to bypass all water going to the exhaust system and it dumps out the transom so i can dry the manifolds and pipes out if needed. This actually works awesome.
I hope this will help any other boaters out there.
232, can you post up some pictures of your set up?
Mohavvalley is offline
Old 06-30-2018 | 12:07 PM
  #32
232
232 is offline
