-   -   k plane rams/trim cylinders... (https://www.offshoreonly.com/forums/do-yourself-boating-budget/306148-k-plane-rams-trim-cylinders.html)
ka0tyk 12-08-2013 03:21 AM
finding a pair of 1 piece trim cylinders is proving to be pretty difficult and quite expensive. is there anything special about the trim cylinders? would it be possible to use a 2 way welded cross bar cylinder with the correct stroke/bore? they all seem to be rated at 2500-3000psi which is the same as what the trim pumps put out. thoughts?
http://www.splitez.citymax.com/i//ea_1.jpg
mercruiser parts lists a cylinder assembly at like $350 each... yikes.
i did notice that there is a mayfair trim tab system that was bought out by hardin marine. I have asked them if they sell the cylinders separate and its been a few days with no response...
mptrimshop 12-08-2013 03:52 AM
I highly doubt merc makes there trim cylinders..... What do the non merc ones cost?
