coolong system 87 454 alpha one combo >
Old 12-16-2013 | 12:11 PM
Default coolong system 87 454 alpha one combo
This boat has a closed cooling system which is very old ...not working and a plumbing nightmare...so it's gone. Ive read quite a bit on crossover system's and they seem to be simple.. cost effective... efficient. Here is a crossover that seems to fit the bill.....http://www.cpperformance.com/p-13357...th-bypass.aspx Other than new tubing would i need anything more.
The engine 330hp 1987 454...new SEI drive...thru the hull exhaust.
Pliant is offline
Old 12-16-2013 | 03:25 PM
Don't do it IMHO...Big Blocks run hotter than Small Blocks and you are already against the wind pulling cooling water thru an Alpha drive. Put a good high quality marine circulating pump on that motor and run it.
sprink58 is offline
Old 12-16-2013 | 05:48 PM
masi242's Avatar
Sprink is right on a good circulation pump is the way to go. I run the same set up 454/alpha combo, should be able to find one in the classified section for under $100.
masi242 is offline
Old 12-16-2013 | 06:51 PM
Intresting a closed cooling system is by no mean's more efficient than a pure raw water system how could it be. As to the sea water pump does it not by far out pump the block pump...Actually i would think the block pump hinder's the sea water pump...A bit like a low pressure fuel pump compared to a high pressure pump
Pliant is offline
Old 12-16-2013 | 07:07 PM
The seawater pump supplies the water .The circulating pump does ....guess what?...circulate .Just get a newer style thermostat housing with only two outlets and you can clean up the motor .with a circ pump
motor is offline
Old 12-21-2013 | 05:13 AM
what i did with my fwc in the hatteras was run the exhausts raw water and use the closed cooling for engine only. then the heat exchanger doesn't hafta reduce exhaust manifold heat, just flushes it out the back with riser heat. screw the manifolds. let em rot. you need the antifreeze to stop the heads from rotting through at the valve guides.
dereknkathy is offline
Old 01-25-2014 | 07:42 PM
http://www.cpperformance.com/p-13922...ater-pump.aspx
Is that pump as simple to install as it look's....Just bolt up to the flywheel and secure it with the this l- bracket
Any input would be appreciated. I would be installing a freshwater pickup and using the drive's pump for a shower......Or could i just pull water thru the alpha drive
Pliant is offline
Old 01-26-2014 | 06:51 AM
yes that install is that simple. good pump too. crusader uses that design for a reason. i don't know how well it would pull thru the alpha. you mean with or without impeller in alpha drive? i am pretty sure the alpha upper is cooled with that water flow, so that needs to be considered. what would you do for shower? just let it spray inside transom assy? or fab some kinda fitting so it sprays back at top of drive?
Old 01-26-2014 | 12:08 PM
Actually pulling thru the drive is a bit hair brained but this is all new to me so i asked.As to pickup's what would anyone recommend iv'e stated lack of experience and can see a potential for a perssure mismatch when running at high speed's...aka the pickup taking more volume than the pump can pull... This is really new territory and i am trying to save myself from doing twice...maybe three time's.
Thank you dereknkathy
Pliant is offline
Old 01-27-2014 | 04:09 PM
masi242's Avatar
I have the same set up 454/alpha combo I had a bad clog in the tube coming thru the transom so I would get hot going thru a idle zone, fixed now. But still very curious about doing the same thing I like the pump just not sure what to use for a good pick up. I have been told not to pull water thru the alpha, that`s to bad it could not be that easy.
masi242 is offline
