Swivel pin replacement...
Old 01-18-2015 | 04:36 PM
  #81
Originally Posted by motor
How much total time in that
hmm.. I didnt do all at 1 time, but prob about 6-8 hours total?
Pulled drives and helmets 1 day (2 hours) then gathered parts and JR kit.
Doing kit was probably the longest part. I started yesterday and forgot bellows adhesive so I had so stop after I couldnt find around town. Putting back together went quick.
Would have been less if I was closer to my shed, and since I spread over 3 days, pulling tools out each time and picking them back up.
nailit is offline
Old 01-18-2015 | 05:18 PM
  #82
Your window looks great...a lot better than mine did. I used a black RTV silicone on the plate to seal it up on the drive and spread it out with my finger as J&R suggested and had no issues. The only thing I did differently from what J&R said and sent was the 1/4-20 socket head cap screws...I didnt use them. I just didnt feel warm and fuzzy screwing a 1/4 stainless steel bolt into aluminum with only about 1/2 inch of depth. I used 1/4-20 stainless steel studs with a small does of blue loc-tite on the threads, then installed the plate and held in it place with 1/4-20 lock nuts. You did a good job from what I see in the pic. You might notice the steering being just a tad stiffer than it was before, but no biggie.
pslonaker is offline
Old 01-18-2015 | 05:27 PM
  #83
thanks, I was trying to watch how tight I tightened the pin (raising it up), the P was good, but the S was too tight so I ended up loosening the steering again and backing off the nut a hair to "hopefully" not be too tight!
Yes the studs sucked! Since your only going in 7/16" in, my tap was barely making any threads, so I drilled them a lil deeper, 6 worked, I had to go get longer studs for 2 since they wouldnt bite.
I also used the black gasket stuff, should be good, now I just have to order some new mercury decals on go on the drives to look somewhat stock.
But I am happy with the job, VERY tight than it was before. All I have to do now is readjust my elec. trim gauges. I had them dialed in pretty good.
A friend offered to let me use a drive jack, but my alum swim platform works pretty good with a small cambuckle strap... They went right in...
nailit is offline
Old 01-19-2015 | 07:39 PM
  #84
Wife made me a pair of decals to match what was under the plates!!
[ATTACH=CONFIG]535906[/ATTACH]
Attached Thumbnails Swivel pin replacement...-image.jpg   Swivel pin replacement...-image.jpg
nailit is offline
Old 02-14-2018 | 10:13 PM
  #85
Default Question
I have the same issue I have the motor pulled and the pin removed by a local marine repair shop. If my pin is corroded and the housing is also corroded will a new pin and bushing set keep it from leaking again or will I need to replace the outer housing?
HenryG is offline
Old 02-14-2018 | 10:30 PM
  #86
Get the stainless steel pin along with the bushings and the new seal and you will be good. Dont get the Mercruiser pin as it is carbon steel. They should know better and use stainless, but they dont care. The aftermarket stainless is the way to go.
Old 02-15-2018 | 07:21 AM
  #87
How do you diagnose a bad swivel pin?
TorchLK is offline
Old 02-15-2018 | 07:36 AM
  #88
play or wobble in the gimble or tiller is the first sign....
phragle is offline
Old 02-15-2018 | 09:44 AM
  #89
I would dual ram full hydraulic steering. Can you give me advice on how I would check this?
TorchLK is offline
Old 02-16-2018 | 10:01 PM
  #90
You can lift up on the drive, mine had a little play there, but mainly on the steering arm. It was also the caus of my leak, I stuck a hose in the stern steering arm access hole and turned the water on. It leaked out the drive... found my culprit, if it could come out, it could go in. Seal was bad.
nailit is offline
