-   -   self aligning roller rockers (https://www.offshoreonly.com/forums/do-yourself-boating-budget/307060-self-aligning-roller-rockers.html)
Titan907 01-05-2014 05:10 AM
Is there any downside to using self aligning roller rockers over non-self aligning?
FIXX 01-05-2014 10:00 AM
self aleigning rockers are for a stock small block vortec cylinder head...if refering to big block and if you have a huge lift cam then td shaft style rocker is the way to go..
Titan907 01-05-2014 10:45 AM
Yes, they are stock Vortech heads. 350 Mag MPI. 1.5 ratio. Thank you
79formula 01-05-2014 01:20 PM
If you are running Vortecs, you must use self aligning rockers. If you don't they will quickly slide off the valves.
Titan907 01-05-2014 03:54 PM
Thank you. That was what I ordered. Just wanted to be sure.
