350 mag mpi  7.4 efi  interchangable? >
Old 01-14-2014 | 06:08 AM
Default 350 mag mpi 7.4 efi interchangable?
looks like i am buying a hurr sandy hulk. usedta have 350 mag mpi motor. i have found a bad complete 7.4 efi motor. will it work? they are both 2000 model year. if i rebuild my gen IV 454 motor, will these heads work? can i put the efi intake on gen IV heads? or aftermarket alum ones? and mainly will the harness plug in and run the engine? is this a closed loop (o2 sensor) system? or open loop? where is ecm? if not bolted to motor, will small block ecm run the 454? can it be reprogrammed? i am probly gonna drop carb small block in it at first, but would like to know my options. thanx.
dereknkathy is offline
Old 01-14-2014 | 06:28 AM
Small block intake will not fit a big block. Everything will probably be wrong.
Crude Intentions is offline
Old 01-14-2014 | 11:01 AM
pls read the post. i asked if the stuff would fit a gen IV big block, and if so, would it plug in electrically to the small block mpi harness. and will a small block ecm run the big block. i didn't ask if i could put 7.4 efi on a small block. the orig 350 mpi motor is gone along with all accessories and all of the fuel injection.
Old 01-14-2014 | 01:04 PM
Knot 4 Me's Avatar
The original 350 MAG MPI's ECM would have been bolted to a bracket that was bolted to the motor (on the exhaust riser I believe) so if you don't have the motor you do not have the ECM. Open loop system.
Knot 4 Me is offline
Old 01-14-2014 | 01:11 PM
Panther's Avatar
Frank's Marine Service
If you change your mind and want to go with a 350mpi, I have one for sale. Refreshed with a lot of new parts.. $3,500 drop-in motor.
Panther is offline
Old 01-14-2014 | 04:15 PM
ok, so if this 7.4 is complete with ecm, can i plug it into the 350 wiring harness and have it run? or are they diff harness-plug?
Old 01-14-2014 | 06:20 PM
Same plug.
Blueabyss is offline
Old 01-15-2014 | 12:19 PM
Is this a tbi system..mpi...mefi or merc 555
Pliant is offline
Old 01-15-2014 | 01:11 PM
pretty sure it is a mpi system.
Old 01-16-2014 | 07:13 AM
hurr sandy hulk. usedta .
I read this far, and quit...........
92nsx is offline
