whats the difference between these two couplers >
Old 06-01-2014 | 07:58 PM
  #31
hi folks well it turns out that the tool fits fine I just needed to push a bit doh! the stock 454 coupler only had 3 bolts the coupler on the 502 had 8 I think
I stuck with that one, I did notice that the 454 had a plate behind the flywheel, is that mandatory?
located in toronto
Originally Posted by Port Monster
Stimleck = where are you located??
stimleck is offline
Old 06-03-2014 | 06:17 AM
  #32
plate behind flywheel is probly balance plate to adapt 350 or other neutral balance flywheel to ext balance 454. not NEAR as good as correct flywheel. also, they could be wrong about needing it or getting correct one. ck flywheel part number and look for balance weight cast into outside of flywheel.
dereknkathy is offline
Old 06-03-2014 | 06:27 AM
  #33
Full circle coupler on the 502 and other bravos ,is held on with 6 bolts...
located in toronto
motor is offline
