Want to add a Transom Trim/Tilt switch on a Cobalt 226 >
Old 03-30-2014, 04:15 PM
Red face Want to add a Transom Trim/Tilt switch on a Cobalt 226
I have a 2000 Cobalt 226 that I would like to add a Transom Trim/Tilt Switch.
Do I need to go to Cobalt and get the switch or are there some aftermarket folks that would have what I need. I also assume that the wiring would most likely be somewhere in the back end since it was an option???
Any help would be appreciated
3pointstar
3pointstar is offline
Old 03-30-2014, 04:21 PM
Dave M's Avatar
It's Mercury part #87-815200A02. Around $50.
Depending on where you want to mount it, it's an easy job. You will have to drill a 1/2" hole at the mounting location. Also, you want to mount it in close proximity to your trim pump. The harness is not that long.
Dave M is offline
Old 03-30-2014, 07:46 PM
can this be added so I would have one on the transom and one on the shift lever?
stimleck is offline
Old 03-30-2014, 07:56 PM
Ya, it's just wiring.
Cole2534 is offline
Old 03-31-2014, 07:20 AM
And I thought they were just for outboards. Never knew they made sutch a thing
92nsx is offline
Old 03-31-2014, 07:39 AM
Dave M's Avatar
The thing I like the best about those switches is that I don't have to climb under the cover to raise and lower the drive when the boat is on the trailer.
Dave M is offline
Old 03-31-2014, 09:04 AM
They come in handy. The boat should never be stored with the drives up.
Katanna is offline
Old 03-31-2014, 09:48 AM
Knot 4 Me's Avatar
Easy install. Done a few of them. As stated, locate near the trim pump. Plug and play. Just make sure to drill the big hole perpendicular to the mounting surface or it wil not sit flush and the gasket won't seal..
Knot 4 Me is offline
Old 03-31-2014, 12:11 PM
Charter Member#157
MnFastBoat's Avatar
Not true on outboard only, I have it on my Twins
Only way to deal with I/O's!!
Makes a great power step to get back in the boat too
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 03-31-2014, 01:49 PM
Received 4,392 Likes on 1,257 Posts
Wait.. you mean i can stop yelling at my wife "UP , DOWN, A LITTLE MORE, BACK UP, TOO MUCH"
ICDEDPPL is online now
