Rewiring Boat
Old 04-02-2014, 07:56 PM
Originally Posted by inspector747
I did the exact thing with my Mirage (Tinned), I bought a tinning pot just for that purpose and heat shrink tube for the ends, only reason I was/ am asking is I had someone tell me that you can go to large and it will be counter productive. So I wanted to check before I order my wire again.
Bryan
That "someone" is an idiot
pstorti is offline
Old 04-02-2014, 08:58 PM
Received 4,386 Likes on 1,253 Posts
So are you guys trying to say that 10 gauge house wiring with a couple of splices isn`t good enough for a 100 amp alternator to starter wire???
lol
btw, this place is great, I ordered (2) tinned 3.5' 6 gauge wires with custom ends , (they make everything for ya) ... for $20
http://tinnedmarinewire.com/wire/
ICDEDPPL is offline
Old 04-03-2014, 02:00 PM
Originally Posted by ka0tyk
marine cabling also resists gas/oil/UV/corosion and proper marine connectors/lugs with proper crimping and insulators to resist loosening from vibrations.
whatever u do, dont listen to anyone telling you to go buy "welding cables." /facepalm.
Ayuh,.... Donno where yer goin' with That comment,....
But I'll discuss the merits of the sentence above it,...
The ONLY draw-back of runnin' weldin' cables, Vs: tinned marine battery cables, is the Tinning,....
Weldin' cables have neoprene sheathin', not Plastic/ vinyl,....
The neoprene is many times More durable to gas/ oil/ UV, 'n anything else ya throw at 'em,.....
Look at the Abuse of a jobsite,...
Weldin' cables make clean installations, as a cable twice the diameter, can be run in 1/2 the radius,...
Weldin' cables, bein' fine strand cable is almost immune to Vibration issues,...
And are of lower resistance,...
Weldin' cables, are crimped everyday, with any end ya want,...
You can seal the ends, with whatever sealant you believe in,....
Weldin' cable's Only downfall is immersion in Saltwater,...
'n to be honest, Immersion in Saltwater will kill any, 'n every wire on a boat, anyways,....
I ran weldin' cables in my barge over 15 years ago,... No problems yet,...
granted, I'm up here on the sweetwater seas, so brine ain't an issue,...
Bondo is offline
Old 04-04-2014, 08:44 AM
$9.53 each
ICDEDPPL is offline
Old 04-06-2014, 10:35 AM
What crimp tool is everyone using?
Cole2534 is offline
Old 04-06-2014, 05:10 PM
inspector747's Avatar
I am going to solder my lugs again and then heat shrink
inspector747 is offline
Old 04-07-2014, 02:35 PM
Crimping large gauge wire can be difficult. A tool can be several hundred dollars.
Some battery, automotive or car audio shops have the proper tools and will usually do it for a couple bucks.
In a "pinch", I use vice grips to fold each wing into the wire bundle then squeeze side to side to bring it back into round.
Edit - As I looked this up, Ancor 701010 has a striking die on Amazon for $80. I see Sea Choice has one 50-61241 that should go for $45.
An alternative is using a terminal with a solder cup. You need a small torch to melt the solder in the cup then plunge the wire into the cup and let solidify. A standard solder gun cannot generate enough heat fast enough to solder large gauge effectively from my experience.
For crimping up to 10ga Ancor 701030 is so superior to the cheap $5 crimp pliers I cant put into words.
http://www.amazon.com/Ancor-701030-D...anchor+crimper
ChargeIt is offline
Old 04-07-2014, 05:14 PM
Ayuh,.... I've got one like this, only older, 'n American made,....
I use it to crimp alota bigger crimps,...
Especially for Weldin' cables,....
Bondo is offline
Old 04-07-2014, 06:55 PM
That really depends on what im doing and how much they are paying lol..all bs aside i like the silver hyd one the best for battery cables..-4/0 is no problem..
FIXX is offline
Old 04-07-2014, 09:31 PM
I use an old set of wheel weight plers they have a point inside the handle. Put the end/ wire in between smack it with a hammer. Block of wood and a dull chisel works well to.
Black Baja is offline
