TRS transmission losing fluid >
Old 05-23-2014 | 06:27 PM
donzi matt's Avatar
I thought that was the oil cooler? I think on my 420's they are on the starboard side of the block, but I could be wrong.
donzi matt is offline
Old 05-23-2014 | 07:32 PM
I've got to say the obvious. The cooler is the one the cooler lines from transmission go to..................Probably tucked under one side of motor ,under the mounts
motor is offline
Old 05-25-2014 | 12:40 AM
Craney's Avatar
Originally Posted by Borgie
Not a TRS expert, but Type F fluid is known for lack of friction modifiers (ie DEXRON type fluids contain quite a bit vs F) faster shifts, better lockup etc at higher temps encountered in a racing application. Used quite a bit in drag racing transmissions.
Would a Dexron fluid work in a velvet drive trans??
Craney is offline
Old 05-25-2014 | 01:24 AM
Crazy if it is being blown out the cooler on the pressure side and being dumped out on the cooling water side being it is a fresh water boat. But killed a trans in saltwater having the same thing happen with the cooler going out in minutes. /
It was not a cast cooler that went out. What is your cooler?
tommymonza is offline
Old 05-25-2014 | 09:34 AM
yes it will work. A buddy of mine runs it in his. I've always used type F based on the merc manuals and Marc from Bam. I see no reason to steer away from what has worked for many years and many velvet drives behind some big power.
MILD THUNDER is offline
Old 05-25-2014 | 08:46 PM
cigrocket's Avatar
Huber and Speedmasters always said F only. Everything else increases your chance of slip and failure. It's cheap insurance
cigrocket is offline
