ECT Sensor help
I hear ya on the scan tool! I enjoy reading and learning so no harm done. As long as the weather isn't complete crap in the morning, I'll head your way. I'll text ya when I leave rapid.
I have had to a few of these ,easiest way is with a 3 pin potentiometer, may only take 30 ohms to bring some artificial enrichment when warm .if your trying to get out of cold start enrichment you will have to bypass ect alltogether ,now your risking a cold start backfire ,you don't want that ..or the full flow of your water pump going out the exhaust ,all the time ,a real hp reducer there
It does have the ATI crossover cooling kit. We un plugged the ect sensor and put a 1000 ohm resistor in its place and now it runs way better. Also, per the pro charge instruction manual, there is no T stat. I did install a restrictor tho.
