Dyno Results
Old 07-08-2014 | 07:44 PM
  #61
SB
Without a wideband I go #2 sizes jet richer than best performance and check my plugs here and there for specs of aluminum. Without mag glass they usually appear like pepper specs.
With a new to me carb I jet richer for first jet change. #2 each time (if going bigger or smaller)while keeping the carb's factory prim to secondary jet spread the same.
Only change to this is if 1st or 2nd run is bad lean, then I jump a bunch. Doesn't happen much cause a properly chosen carb won't be too far off.
SB is offline
Old 07-08-2014 | 09:53 PM
  #62
Wish I could run the O2 Wideband, but i have the dreaded Lightning O2 sensor killers.
Budman II is offline
Old 07-08-2014 | 10:22 PM
  #63
Rookie's Avatar
I have put in and pulled out O2 sensors in Lightning headers once on plane. Sometimes the only way to tune.
Rookie is offline
Old 07-09-2014 | 06:27 AM
  #64
That sounds like it may have been fun...
Black Baja is offline
Old 07-09-2014 | 02:37 PM
  #65
Maybe get some marshmallows on a stick and make s'mores.
Old 07-09-2014 | 07:51 PM
  #66
You know I never thought of that. Who needs a grill when you have exhaust...
Old 07-09-2014 | 09:11 PM
  #67
Rookie's Avatar
Lol, 15mph on plane and hatch up a little, is pretty uneventful.
Rookie is offline
Old 07-15-2014 | 07:48 PM
  #68
been reading you all threads on jets...Ive been running 78 and 86 on my 496 stroked, alm. heads, deamon 750 and there still black rich.6.5 valve primary only.. maybe I got something else going on .. any thoughts??
redcorvetteman3 is offline
Old 07-15-2014 | 07:54 PM
  #69
SB
Jetting is more dependant on the carburetor itself. Do not follow jetting from another part# carb.
And then of course the motor build up and use itself.
Anyone notice that on most Holley's, most 600cfm+ carb will have jets in the 60's , most 700+cfm carbs will have jets in the 70's, 800+'s in the 80's, 900+'s in the 90's ???? LOL. Ka winky dinky huh ? LOL.
Smaller venturi's and throttle blade size with same booster pulls more fuel for same given amt of air pulled thru.
Edit in: I see you have a Barry Grant carb. You really can't compare jetting and other things with a BG vs an 'equivalent' Holley.
SB is offline
Old 07-15-2014 | 08:40 PM
  #70
ok yea that makes sense so based on most others with simialer engines does my jetting seem reasonable
