hard steering.  rack vs rotory steering system >
Old 07-20-2014 | 08:49 PM
Default hard steering. rack vs rotory steering system
I have a 88 fountain with twin trs out drives.The steering is hard. It has hydrolic stableizers. It also has a rotary steering system for the cable. What can I do to mane this turn with less effort. I was thinking of changeling to a rack and pinion cable set up but i m not sure it would help. Please give input.
creativecustoms is offline
Old 07-21-2014 | 06:11 AM
needs full hyd upgrade...most fountains came with full
ezstriper is offline
Old 07-21-2014 | 11:12 AM
Where can I get a full hydraulic system?
Old 07-21-2014 | 04:34 PM
CP performance sells a inside kit, others as well...
Old 07-22-2014 | 08:48 AM
bcfountain's Avatar
Registered User
I just went through with this on my 10meter.the boat came with add on hyd assest stering.meaning it had a rotary cable controller and cable that ran to the transom control arm.the rotary controller had a lot of slop in it.i could have made it full hyd from the helm to the transom or replace the rotary/cable system.the full inside hyd kit was 1100.00 plus.the new rotary control w/a no feed back control and cable was under 400.00 with shipping.the later kit is a better choice.but money was tight so I did the rotary.was also going to be easyer to install.
bcfountain is offline
Old 07-22-2014 | 03:03 PM
Did the cable make it turn easyer?
Old 07-23-2014 | 07:43 AM
bcfountain's Avatar
Registered User
yes.i never had a problem with the steering being hard to trun.just had a lot of slop.the no feed back control takes all but alittle of the slop out.
Old 07-27-2014 | 11:18 PM
Thanks for the info Guy's. I appreciate it.
