-   -   Alternative to Mercruiser engine water pump? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/315579-alternative-mercruiser-engine-water-pump.html)
Jonesyfxr 07-21-2014 08:01 AM
I see lots of you guys are able to cross reference parts to automotive items. I think I'm going to replace my engine water pump while I'm doing my impeller. What are you guys going with? It's an 86 350.
motor 07-21-2014 08:51 AM
don't use an automotive circ pump on a raw water cooled marine engine. You can google why
Jonesyfxr 07-21-2014 01:34 PM
Ok thanks. I wasn't sure if it was a possibility.
Trash 07-21-2014 01:34 PM
You need the marine unit for the stainless impeller and back plate.
Jonesyfxr 07-21-2014 01:51 PM
Ok thanks!!
BUP 07-21-2014 02:20 PM
And the internal bearing sealing is better corrosion resistance compared to the auto side.
Tinkerer 07-21-2014 09:16 PM
I had a water pump go bad and just bought the auto version and pressed the NEW bearing assembly out of the new one and installed it in the boat one. Worked perfect and never leaked.
motor 07-22-2014 05:45 AM
Seems like a lot of trouble when a replacement marine pump is only 100 bucks or so.. mercury retail is 144.00
http://www.boatersland.com/sie18-358...FaVZ7Aod0D0ARw
QUOTE=Tinkerer;4157369]I had a water pump go bad and just bought the auto version and pressed the NEW bearing assembly out of the new one and installed it in the boat one. Worked perfect and never leaked.[/QUOTE]
Jonesyfxr 07-22-2014 08:31 AM
Thanks for all the help guys!
OSO to the rescue.....yet again!!
BUP 07-22-2014 04:22 PM
And not sure about this as for this year but the Sierra water circ for V-6 and V-8 small blocks (the same pump used) was the exact same that mercruiser used . Cheaper in price on the Sierra side.
