525 Help
Old 09-06-2014 | 06:17 PM
Default 525 Help
Hi guys, I lost #5 cylinder in one of my 525s. Compression is good and has new plugs wires and fairly recent coil packs. If I run engine and pull injector harness off that injector there is no change in engine. I put a noid light on injector plug and it lights up like all the others that are fine. Overnighted a new injector in and installed it hoping to salvage the weekend but still does the same thing! I should also mention the top ends were done about 30-35 hours ago. I pulled the valve cover and everything looked fine. Any ideas would be appreciated!! Thanks
W900 is offline
Old 09-06-2014 | 06:31 PM
obnoxus's Avatar
Charter Member #1171
Get another plug,,, plug it into #5 wire and ground the plug to the block,,,,,,does it spark?
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 09-06-2014 | 06:46 PM
Spark getting to #5? You need 3 things, spark, fuel, and compression.
Sounds like maybe you lost a coil?
MILD THUNDER is offline
Old 09-06-2014 | 06:51 PM
I should have mentioned that it does have spark. New plugs and wires and I grounded old plug to block to check spark. Coil packs are new also.
W900 is offline
Old 09-06-2014 | 06:52 PM
do a compression check..might have bent a valve or blown a head gasket..or it blew between the cylinders..common on the 502 blocks..
FIXX is offline
Old 09-06-2014 | 06:54 PM
p.s. also make sure your headers are not leaking water into that cylinder..
FIXX is offline
SB
Judging by you diagnostics and actions - I agree with both above. Check for spark.
Wouldn't be the first time a newer plug or wire or coil schit itself.
SB is online now
Old 09-06-2014 | 07:18 PM
donzi matt's Avatar
A weak coil can fire a plug at atmospheric pressure, but in a compression situation it will not. This is the reason why stock ignitions won't cut it in higher boost applications.
It would be worth it to swap coils around and see if it follows the coil.
donzi matt is offline
Old 09-06-2014 | 07:54 PM
get a spark checker that is adjustable,set it at ,100 thousants gap ,the spark should be bright blue.as mild mentioned you need 3 things for the cylinder to fire,1 good compression 2 proper mixture of fuel&air and 3 good spark at the right time.the cylinder not firing is lacking at least one of these things.you said the compression is good and you replaced the injector and the noid lite lites up so i would swap the coil from a different cylinder and see what happens.
mike tkach is offline
Old 09-06-2014 | 08:15 PM
Thanks for the input everyone! I pulled plug wire and put plug against lifting eye on engine and it has real good spark. Going to try running with no water to header in the morning to see if I get anywhere.
W900 is offline
