cant get over 50mph why why
My Baja 212 islander with 454 MPI would do between 65-67mph with a 3 blade 21 pitch bravo. That was with a BB so I don't think the small block will push it much past 55-60 unless it is built and has some torque.
Are you trimming up? Sorry but there was not reason to change gear ratio, and you were better off with 1.47. Where is the timing set? That 600 cfm carb should be fine out of the box so I hope they only adjusted idle mixture.
If you can use better english typing - i'm not that picky but you are giving me a migrain - maybe we can have a better conversation.
#1 - those gears are bullchit. They just took power away from you. Did you run the new motor build with the old gears ? And if so, what happened.
#2 - comp makes many different extreme marine cams. Please list exactly what cam they used.
#3 - what heads ? If factory, which style or year ?
#4 - which intake manifold
#5 - what pistons did they put in your new motor. Manufacturer and part# is needed. Not a description of flat top/dome/or etc as that can lie to you as far as compression.
