How can you tell what scored your cylinders?
I have a question about cylinder scoring. How do you tell the difference between fuel cylinder wash down and cam debris from a improperly broke in cam ( new motor). Lets do this right ! :)
Rutrow!
Originally Posted by mcprodesign
(Post 4196886)
I've never had cylinder damage from a lost cam either! Have you just checked the oil and cut the filter, is that how you established the cam debris, or have you pulled the pan and intake? Is there already cylinder damage or was that a question?
(Post 4196886)
Leaking exhaust. Water getting in cylinders. Common problem.
(Post 4196886)
if this is a new build and detonation did not cause it id check the ring end gaps,probibally not set correctly and the rings were hanging up in the cylinder bore.
I put 1 pic of where I could be sitting out on a lake ,its a hundred here right now. Motor has an hour on it. I think the lifter never spun.
Damn that sucks. You just had this one done.
