-   -   Compression test? (https://www.offshoreonly.com/forums/do-yourself-boating-budget/319025-compression-test.html)
airjunky 10-13-2014 07:34 AM
Lots of opportunity for a.lucky break till oil consumption and plug fouling join the table.guy.here in Texas has a gen 6 454 cheap with a carb .roller cam better heads ,prob less years of internal erosion ,leave you some money for fresh manifolds serp belt conversion maybe a bravo .yea and keep us posted
Unlimited jd 10-13-2014 07:48 AM
http://www.jegs.com/webapp/wcs/store...1&pgGrp=catNav
Bolt on your accessories, make sure it has brass freeze plugs and go boating.
Please don't buy used heads and just bolt them on. You will never get the entire story. I won't even sell heads to someone that doesn't intend on taking them to a machine shop.
GLENAMY 242SS 10-13-2014 08:09 AM
Masi242 tried to pm your box is full
masi242 10-13-2014 08:50 AM
Cleared pm
masi242 10-13-2014 09:04 AM
Lilred I would like to just use my parts, heads and have everything redone, I wish this wasn't a budget rebuild but with one in college and one is a senior in high school.
Weather looks good for the river run Sunday you'll be driving the TG.
Unlimited jd 10-13-2014 10:28 AM
I copied the link because you said it was looking like about $5,000 to rebuild what you have, which sounds about right. So for a couple hundred more you can have a better package. Then you have a block and some other parts you can sell, be ahead and not be worried in April when the machine shop isn't done lol.
Yes I'm very fortunate that I'll have the top gun on loan for the day :)
GLENAMY 242SS 10-13-2014 11:11 AM
+1 w/lilred
while you are waiting to install look for a pos boat w/bravo drive on craigslist and replace that alpha while engine is out and sell alpha and any other goodies from doner boat to recoop investment.
Keep us posted good luck
masi242 10-13-2014 03:59 PM
Thanks Gary nice talking with you
onesickpantera 10-13-2014 04:21 PM
Originally Posted by blue thunder (Post 4201823)
How is the compression on #4 vs the others? From your description I was leaning towards number 4 is sucking oil through the intake gasket, from the lifter valley. If it runs good until the #4 plug fouls I would look at the intake gaskets and even the intake itself for a crack.
I agree look at other isues before you lay your money cown for a rebuild. First thing I would do is try another gauge as your numbers are consistant. Very unusual for all cylinders to all lose compression. I am usually looking for the spread between highest and lowest as a sign of an issue.
masi242 10-13-2014 06:19 PM
Thanks pantera I was talking to another OSO member and he also suggested doing a leakdown test to double check. So when I do the leakdown I should pull all the plugs and have choke open full. If I am missing something please let me know, I am still learning.
