Best aluminum heads out there??
I just had a pair of brodix 2plus hand ported.
They are 312cc "as cast". After porting, probably closer to 320cc. The chambers came CNC finished and measure 124cc (just verified via "CC'ing" for CR calculations).
The heads flowed 396 on the intake and 330 on the exhaust. Pretty good I to E ratio.
The guy who ports all our stuff said he was impressed with the quality of the castings.
I'd seriously consider the AFR's if I was starting from scratch as you won't hear a bad word about them from most who have experience with them.
That said, I'd have ANY assembled head taken apart and set up right as most assembled offerings still need work. Also, cnc porting is great for a consistent "baseline" but will benefit from hand finishing.
*edit* heads are going on a 515ish (final displacement upon bore size) NA, 6000 rpm pleasure boat engine.
Pretty sure he opens them to .700.
I'll check the sheet when I see the machinist tomorrow.
Maybe I'm goofed up on the exhaust flow as that does seem high.
According to the brodix site they flow 340 and 240 "as cast".
A local old timer that's been at this for longer than I've been alive does my stuff. He used to do quite a bit of work for the local shops before CNC came around.
I'll report back as I certainly don't want to give bogus info.
*edit* 313 not 330 on the exhaust. Also, 2.30 intake valve instead of the 2.25 the heads come with.
290/305/315 (as fas as size )on 502-540's is almost like splitting hairs.
Torque at planing speeds and below is useless for 99%+ of boats.
When you have heads as good as the AFR's there will not be a huge difference.
Pick which you want and be happy. Because you will be.
My IMHO would be the 315's.
Bang for the buck, AFR 305 with CNC chamber option. If you are seeking max effort, and don't mind spending the extra dough, the full CNC 315 version would be my choice.
Darts full CNC 335 is a nice head as well, but not cheap. I'm not too up to date on the brodix stuff, although their big ovals seem pretty bad azz too.
Did you measure the runners after the full cnc porting? I understand what you're saying about port velocity but I've also seen several examples of 305-315 make plenty of power over a wide range of rpm. Mercruiser used 319 cc rect ports on 365's seemed to have enough velocity for that.
i have been using dart heads for years but on a recent build i contacted bob madera for a cam and in our conversation he recomended a set of afr 315 cnc head for this build,so i gave them a try.when they showed up i opened the box and i was very happy with the heads.they look like man candy.the quality was as good,if not better than the dart,s and were quite a bit cheeper.i finished the build and went to the dyno,the engine made 60 more horse than i expected and the torque was huge.im not saying the afr head is best for every engine but for what we do,marine engines,im sold.
steve,bob madera works directly with tony,the owner of afr,he can get you a cylinder head designed for your application and ready to bolt on.with bob,s knoledge and afr,s quality,even a dummy like me can make power.
BB........how come cam grinders ask for the head flow numbers before they grind a custom cam?
Is it that to the average "sportsman" type enthusiast, the flow numbers are still relavant for sizing components and designing an engine combination?
