Re-power build up advice
Old 12-06-2014 | 12:09 AM
If you are replacing the internals this is what I did and it works pretty good.
*1987, MIE/340 (7.4) 454 4 Bolt Main Big Block
Dipped And Honed The Decks And Cylinders Cut .060 Over
Block Was Detailed With All Casting Debris Removed
*Scat 9000 Crank 4.25, 496 Stroker - cut .020 under
*Scat 26385716 - 6.385 in. Connecting Rods - Floating Pins -I Beam Forged 4340 steel
Howards Cams 120255 - Max Torque Retrofit Hydraulic Roller Camshafts, Hydraulic Roller Tappet, Advertised Duration 288/294, Lift .585/.610, 112 L/S
Howards Matching Valve Springs 98636 - 130# / 330#
Cloyes Gear 9-203 - Cloyes Wear Plate, .031 in. Thick
CCA-205 Cam Button
Maxspeeding Hydraulic Retrofit Roller Lifters
*Probe 496 Dome Top +18.0cc, .060 - SRS - PHV Series Piston Set
Clevite 77 Cam Bearings
*Federal-Mogal 4400 M20 Main Bearings
*King Engine Rod Bearings CR849HP
Cloyes True Double Roller Timing Chain
Mahle - 4.310 Plasma Moly Coated Piston Rings
Melling 10778C (Anti-Cavitation) Oil Pump
Melling HV Oil Pump Shaft
New Solid Harmonic Balancer
Rotating Assembly Fully Balanced
*Trick Flow Chromoly Pushrods TFS-21417800-8
Completely Refreshed Chevy BB Heads 14096188 / Open / 118cc / 3 Angle Valve
APR Head Bolt Sets
ARP 1.90 Rocker Studs
Norris S/S 1.7 Roller Rockers
Seal Power Gasket Set
EDELBROCK BBC R2 AIRGAP INTAKE
(Edelbrock 7202 Intakes Gasket Set)
Pro Comp 2752 Fuel Pump
*MSD Ignition
Pro Comp Distributor
Super Stock Coil
8mm Accel Hi Performance Wires
New Single Wire Alternator
Mini (gear reduction and fully marine) 3HP Starter
Edelbrock 800 Carburetor
12" Aluminum, Oval Air Cleaner With K&N Filter
Brass Freeze Plugs
Stainless Steel Bolt Set
4” Stainless Steel "Tall" Risers
496 MerCruiser Exhaust Manifolds
Sherwood Motor Mounted Raw Water Pump
f_inscreenname is offline
Old 12-06-2014 | 09:44 AM
CCA-205 Cam Button
APR Head Bolt Sets
*MSD Ignition
Super Stock Coil
Brass Freeze Plugs
Did you dyno this engine? Seems a little light on cam for a 496ci engine.
MILD THUNDER is offline
Old 12-06-2014 | 11:05 AM
Velocity Vector's Avatar
Crazy Energy
I'd just drop one of these in and call it good.
Velocity Vector is offline
Old 12-11-2014 | 03:10 AM
To answer the question that was asked I would look at a F.A.S.T. self tuning EFI system myself. But there is some good advice to be had here
Jeff P31 is offline
