Engine bearing selection help >
Old 01-02-2015 | 07:25 PM
Default Engine bearing selection help
Looking to purchase rod and main bearings for a 502 gen vi all STD. A lot of bearings out there to choose from and want to purchase the best ones. Are the clevite p-series the way to go?
Satisfaction is offline
Old 01-02-2015 | 08:04 PM
i use the h series,even on stock crank&rods.
mike tkach is offline
Old 01-02-2015 | 08:15 PM
scottw's Avatar
2nd the H series!
scottw is offline
Old 01-02-2015 | 08:25 PM
H series it is!!
Thanks Guys
Old 01-02-2015 | 09:32 PM
The only advice I've seen against H bearings are running them on stock cast cranks. Supposedly they will hurt a soft crank. A nodular or forged crank, h is the way to go.
Quick2500 is offline
Old 01-02-2015 | 11:44 PM
H- typically are slightly narrower for larger radius's also. I've seen people nitrate cranks to surface harden some (will add .0001" or more) and help guard for wear concerns with "H".
IMO, on a stock engine, clearance is more important. Take the time to plasti-gauge all journals. Never rely on STD bearings being equal. I usually buy 2 sets and sometime -1's to get the clearance I want depending what i'm starting with.
Stock engine and crank - i'd use "P".
abmotorman is offline
Old 01-03-2015 | 12:30 AM
king bearings. do some googleing.
beaver 3 is offline
Old 01-03-2015 | 06:09 AM
Ok, plastigauge? Really??? Your buying several sets of bearings to get it perfect yet your using plastigauge???
And as far as king bearings go, the internet hype about the bimetal bearing being made up of 2 thicker layers for better embedibillity (sp?) sold me on them until I torqued up the rods and mains, measured with a dial bore gauge and found the clearances all over the map. Went back grabbed a set of calico coated h bearings and all rods were .0024-.0026 mains were .0025-.0028
Unlimited jd is offline
Old 01-03-2015 | 06:29 AM
Not to start a bearing debate. Because I think proper setup is key. Straight mainline/ cylinders and proper clearance. But I've used Kings with no issues. Every time I pull the bearings out they look new along with crank journals. As far as plastigauge goes. That might b ok for a stock automotive rebuild but past that I don't think so. To much margin for error and it's so much faster using a dial bore gauge. Why in the world would you use plastigauge?
Black Baja is offline
Old 01-03-2015 | 06:36 AM
IMO King bearings are "rebuilder" quality bearings .When you buy an average priced "rebuilt" engine a lot of times they will have "Kings" in them ...They are inexpensive and work ok in non highly stressed engine ....I normally use Clevite...The series ,depends on application.....M.O.
motor is offline
