Needing advice or idea's
Old 01-03-2015 | 03:43 PM
Default Needing advice or idea's
Repowering my 97 Baja 252. New mildly built 509 with CMI headers. No provisions on headers for shifter bracket or oil filter relocation bracket. Looking for ideas on where and how to mount somewhere different. Pictures would be awesome
KR252Boss is offline
Old 01-03-2015 | 03:54 PM
F-2 Speedy's Avatar
You can transom mount the shift bracket & I'd go with a front head mount remote filter
F-2 Speedy is offline
Old 01-04-2015 | 05:30 PM
Thanks for advice. Looks like its exactly what I will do
Old 01-04-2015 | 08:09 PM
you could probably retrofit the pre-alpha shifter. mounts to top 2 bellhousing (flywheel cover) bolts. same distance for shift cable from there to drive.
dereknkathy is offline
Old 01-05-2015 | 05:57 AM
mount both on transom...I would suggest changing all of the oiling system at this point, cooler, block adapter, filter mount, lines as the merc stuff is pretty much junk...lots of old post on this...
ezstriper is offline
Old 01-07-2015 | 01:01 AM
What he said.
You can make a bracket for the oil filter mount pretty easily.out heavy duty angle aluminum or steel and paint it.
Griff is offline
