Need Help Figuring Out the Year Model of My Engine. >
Old 01-16-2015 | 01:46 PM
Default Need Help Figuring Out the Year Model of My Engine.
I have an old mercruiser engine. It has a serial code of m0922ra. Iv tried doing research but I cant seem to find what year model or any info on it. Any help would be greatly appreciated.
boatmaster1027 is offline
Old 01-16-2015 | 02:36 PM
Get the block casting number off the port/ rear side of the block. It's back where the bellhousing bolts up, then run those numbers. It'll give you a time span at least.
Jonesyfxr is offline
Old 01-17-2015 | 06:48 AM
Ayuh,.... Donno where ya found that number, but it don't look at all like a Mercruiser serial number,.....
Bondo is offline
Old 01-17-2015 | 09:13 AM
Casting numbers all the way .if you want to get where you want to go quickly ..and know for sure what you really have
airjunky is offline
Old 01-17-2015 | 12:57 PM
BUP
That is an invalid Mercruiser serial # - I ran it for you and like said above, that doesn't even look like a serial by them as I thought the exact same but still ran it just in case.
If you have a title of the boat that this engine is in or the title of the boat that this engine came out of - a lot of states will post the outdrive and engine serial #'s on the paper work and or titles. No not states al, l but a lot do.
next what is it a V-8 350 Gm, inline 6, or is this a Ford old Mercruiser app ?
BUP is offline
Old 01-17-2015 | 05:31 PM
till BUP posted last line we were all assuming big block chebby. actually it is the most valid question of all...
dereknkathy is offline
Old 01-17-2015 | 07:05 PM
BUP
If I recall the Mercruiser 454 started in 1974 with an inboard serial # starting 37 and in 1977 Mercruiser sterndrives for them with a starting serial # of 426 and before that was the 427 CID in which those serial # stated out with 2???, starting in the 1968 or 69.
- none of the OP serial # s match anything from Mercruiser as the closest thing would 0M but the ra does not fit anywhere as what he posted.
OP says older - how much older than the 0M as these started in 2001 but not even as far as the rest of his serial # posted would match anything in the 90's or the 2000's.
Maybe some pics and a lot more info here is needed like how many cylinders and is this V -8 or an inline engine and GM or Ford engine. Yes Mercruiser did use Ford way back and others.
BUP is offline
Old 01-20-2015 | 08:55 PM
If it is a small block the only thing i could find is this
Code Year CID Vehicle HP RPO Trans Carb Comments
RA 57 283 Truck 160 223 Manual Hydra
RA 58 283 Truck 175 410 Manual 4-Brl
RA 59 283 Truck 175 410 Manual 4-Brl
RA 62 327 Impala 250 300 Manual 4-Brl Hyd Cam, A/C
RA 63 327 Impala 250 L-30 Manual 4-Brl Hyd Cam, A/C
mcprodesign is offline
Old 01-20-2015 | 09:00 PM
m would be where it was assembled and 0922 would be september 22
