Where to send my 496 injectors for service >
Old 04-24-2015 | 07:28 AM
Default Where to send my 496 injectors for service
496 HO MAG 400 hour's. Marren (Injector.com)?
CATF800 is offline
Old 04-24-2015 | 08:01 AM
Knot 4 Me's Avatar
http://www.offshoreonly.com/forums/g...-cleaning.html
Knot 4 Me is offline
Old 04-24-2015 | 08:04 AM
Why do you want to test them, is their a problem?
You can do an injector test through the scan tool. I dont know if its necessary to replace or clean. I had over 500 on mine and I replaced them when I did the engine rebuilds. Never had a problem.
They cost about $60 each
Keith Atlanta is offline
Old 04-24-2015 | 12:14 PM
BUP
I know I have tried to help you out before with your 496 up here. Maybe this can help whomever. In post # 2 of the link below click on that link and read post # 10 of that link. It is just a slight jist of what I do in the injector service. A set of 8 injectors unless they are extremely bad from contamination, I spend about 2 hours on them from start time to finish time. There is a lot more to it than most would know.
Impedence of the injector is very important, Injectors are electro & mechanical devices so they are not bullet proof, plus restrictions, and or contamination happens more times than you would think.
Link below.
BUP is offline
Old 04-24-2015 | 01:08 PM
Injector RX in houston, great rate great service, just one of many
tunertech is offline
Old 04-27-2015 | 08:15 AM
Link below.
Thanks BUP. I called and left a message this AM.
CATF800 is offline
Old 04-27-2015 | 08:18 AM
Yes a few problems. one engine seems to have unburned fuel that will collect and "Pop", cannot get full MPH or RPM. Without starting this whole saga all over here in another post, i just need to get the injectors cleaned/serviced and be certain they're operating to their potential/correctly.
CATF800 is offline
