Coupler question
Old 05-04-2015 | 05:04 PM
stick an outdrive input shaft or alignment tool in it and spin it with starter and see how centered it is...
dereknkathy is offline
Old 05-06-2015 | 04:27 PM
Originally Posted by 33outlawsst
They should be like these, the hole in the coupler is .372 a 3/8 bolt is .356 this will let the coupler move around and not be centered & may cause vibration
My coupler the holes are .392. The flywheel has cobores that are .375 a difference of. 017 even if the bolts had shoulder it could only be .375 to fit in the cobores on the flywheel. I made some stepped pins for three holes then installed 3 bolts then pulled the pins and installed the other 3 bolts. I will check the alignment when I install the engine.
the mayor is offline
