Read my plugs
#32
#33
BB, how ? By reading the ground strap & porcelain, how will that tell you what the motor "wants". I believe it will tell you where your at with heat range & timing (kinda). I am not trying to be D-bag, but please educate me on this if you will.
#34
BB is this what you are saying?
Heat Range = Ground Strap, the ground strap indicates the heat-range of the spark plug. If the "color" of the ground strap "changes" too close to the ground strap's end, (which is above the center electrode), then the heat-range is "too cold" , meaning that the strap is loosing heat too quickly to the base ring, and is not able to burn off deposits until near its end. If the "color" of the strap changes near where it is welded/attached to the base ring (last thread ring), then it means that the plug heat-range is "too hot", because heat is not being tranferred/cooled from the strap to the base ring quickly enough !!!! The strap might begin to act like a "glow-plug", eventually causing preignition and/or detonation later on. Proper heat-range is when the "color" is at the half-way point on the strap, neither too cold or too hot.
But some say thats the way to tell where your timing is at. So what is correct? Reading ground strap for timing or heat range of plug?
#35
