SBC repower with 400
Old 06-22-2015 | 06:03 AM
one advantage of alphas. they are all over the place for 3 to 500 bucks. makes popping shafts a little less scary. but you should have a spare at all times.
dereknkathy is offline
Old 06-22-2015 | 07:08 AM
3 Letters.......LSx
Gimme Fuel is offline
Old 06-22-2015 | 08:46 PM
Yeah I have 2 Alphas for the Baja now. But I hope to sell the Alpha stuff and the boat. Then I'll concentrate on the Formula w Alpha gen II.
NHGuy is offline
Old 06-23-2015 | 01:10 PM
CIG3's Avatar
The Alpha will handle 400HP from a small block as long as you run good lube and change every 30-40 hours and run a drive shower. I would prefer to run a belt driven raw water pump with a HP motor as the alpha pump is not really adequate. I've used the water from the drive pump to feed my drive show with good success.
As for a 383 check this out. You couldn't get all the parts and build one for this price $3500.
http://www.ebay.com/itm/Reman-6-2L-3...5d9f94&vxp=mtr
http://www.ebay.com/itm/6-2-377-rema...681f12&vxp=mtr
CIG3 is offline
Old 06-25-2015 | 09:02 PM
Kind of off topic, but is there any benefit to changing the lower end of one of the alpha's to counter rotate?
suss1173 is offline
Old 06-26-2015 | 11:06 AM
1997 Vortec roller motor. Why are we even talking 400 sbc? With Vortec heads, pound for pound, that 350 is making more horses that the 400 did. (stock or near stock)
Stroke that dude. Way cheaper and a better motor in the long run.
If you were starting with nothing, I've had great success with 400s in boats and say go for it, but here, you'd be tossing out a better engine then you'd be putting in.
CDShack is offline
Old 06-26-2015 | 03:11 PM
if you have a twin alpha boat, maybe...for one engine to do counter-rotating. Only other reason would be to level boat with a really fat wife. And if she eats that much, you cant afford a boat anyway.
Old 07-19-2015 | 10:06 AM
Originally Posted by NHGuy
Any reason I can't put a 400 in where my 350 resides? I just bought a lot heavier boat and I can use the ponies.
As long as you tune it and use the right parts - none.
My 406 slayed nearly everything I came across for 15 years..
UD
Attached Thumbnails SBC repower with 400-photo-1-.jpg   SBC repower with 400-20.8-w-406.jpg
Uncle Dave is offline
