-   -   Power steering pump compatibility question (https://www.offshoreonly.com/forums/do-yourself-boating-budget/327384-power-steering-pump-compatibility-question.html)
amd3073 06-15-2015 11:10 PM
I have a mercruiser part num. 849906A28 power steering pump, it looks like a gm pump . Anyone know if it crosses over to another part number? I'm not interested in paying the $675 for a mercruiser pump
Black Baja 06-16-2015 06:17 AM
You can use a regular old GM pump you just have to swap out the pressure relief valve.
TWIN-SPINS 06-16-2015 06:35 AM
Look at one of my post, it is a Cadillac pump from a 4.1 82-85 Seville engine,,,,get this,,,,rebuilt 46.00 at autovalue parts store,,,add a little paint and use your old relief valve,
BUP 06-16-2015 07:57 PM
You have this ^^^^
https://www.google.com/#q=cadillac+4...33684939257996
mo3d 06-17-2015 09:08 AM
And this cadillac pump definately works. My 500EFI's pump is weak at idle speeds. Makes it interesting around docks !!
Carbon Footprint 06-27-2015 09:20 AM
What if you don't have an old power steering pump to use the relief valve from? Can you buy the right relief valve on its own?
TWIN-SPINS 06-27-2015 03:43 PM
We ended up using the one that came with the rebuilt,,,works fine,,,don't know if there is any difference between marine steering,vs,auto relief valves,,,,I still have the pump I took off,,,the relief valve is still on it,,,,,,,
Carbon Footprint 06-28-2015 08:26 AM
Good to know, thanks Twin.
BUP 06-28-2015 12:17 PM
Pressure ratings are different between the valves for an Auto Saginaw Pump and the marine version.
