Holley float adjustment
Old 07-18-2015 | 08:05 AM
Default Holley float adjustment
I have a Holley 750 carb. on a 454 mag. I have an electric fuel pump hooked and regulator. I know how to adjust the floats, just wondering do i leave the fuel pump running when i take out the plug sites, and is there a marine pressure gauge that i can hook up to the regulator. The pump, regulator are both Holley products. Thanks
Baja 240 sport is offline
Old 07-18-2015 | 08:59 AM
No you don't need the pump running, let it idle a minute, shut it off and remove the fuel level plugs ,adjust as needed, restart and check again,
there is a Marine pressure gauge available, I run one on each engine, I set my regulators at 6 psi.
253 is offline
Old 07-18-2015 | 09:28 AM
McDaniel all stainless gauges are very high quality
GLENAMY 242SS is offline
Old 07-18-2015 | 09:43 AM
Thanks for the help, i will try these two. I will look online for the gauge.
Old 07-18-2015 | 09:49 AM
Hardin Marine may have them
253 is offline
