Dumb question about vacun
Old 08-03-2015 | 07:02 PM
Default Dumb question about vacun
If using an msd ignition distributor and coil are you eliminating the vacuum connection ? If so would there still be a port on the intake manifold to connect a vacuum guage for setting mixture?
stimleck is offline
Old 08-07-2015 | 04:37 PM
I had to add a port to my phenolic carb spacer on my first engine as the intake or carb didn't have a port.
ThisIsLivin is offline
Old 08-07-2015 | 06:25 PM
Marine distributors don't have vacuum connections. They don't need them, no such thjng as light load cruise in a boat.
apollard is offline
Old 08-07-2015 | 09:41 PM
SB
Correct. Plus, I never suggest nor promote driving a boat down a steep hill.
SB is offline
Old 08-09-2015 | 01:41 PM
where do i hook up the vacuum
gauge to set mixture?
stimleck is offline
Old 08-09-2015 | 03:43 PM
Are you set on doing your idle mixture setting by vacuum?? You can do it very easily by turning mixture screws in a little at a time until it drops RPM then turn it out about an 1/8 to 1/4. You can use a hand held tack to help.
Bawana is offline
Old 08-09-2015 | 03:52 PM
Most marine carbs (at least all the ones i've seen) have a vacum fitting. On the holleys it is hidden under the primary float bowl. Hp500 carb came from Merc with one. Has a rubber cap on it.
apollard is offline
Old 08-09-2015 | 06:16 PM
trhanks, my carb has the port but the holley video shows a port on the intake manifold, will the readings be the same? hand held tach that would be easy because my timing light has a tach read out on it
stimleck is offline
Old 08-09-2015 | 07:36 PM
The port below the bowl is manifold vacuum.
apollard is offline
