Upgrading the fuel supply Baja 272 Islander
So even with the new 130gph pump regulated to 6.5psi I set the throttle at 4k and put the missus behind the wheel to watch the fuel pressure guage and watched it drop to 4.5-5psi for the short time I watched it. I can see the value of putting the regulator on the return side, and now have to suss out what's up on the supply side.
Maybe, if it's worn out. However, despite what you'll hear here about fuel pumps, Mercury Racing thinks the stock pump is just fine for that HP level - and was willing to warranty it. For example, the 525sc used it from the factory - with the 3/8 lines.
supply line from tank - T for primary bowl - T for secondary bowl - bypass valve - return line to tank
