building a reverse rotation merc 260 >
Old 10-03-2015 | 12:04 PM
i hope OP wants this engine for an inboard application. you can't spin an alpha or a bravo backwards.
dereknkathy is offline
Old 10-03-2015 | 04:45 PM
have to use the reverse rotation cam, gear set and should use the rear main seal/ft seals but some don't
ezstriper is offline
Old 10-24-2015 | 12:33 PM
thank you guys , i found a reverse rotation sbc that just needed , new rings and bearings ,i found this was easier that trying to change rotation on a standard engine . by the way if you want to know what happened a friend of mine blew a motor n an old wellcraft v-drive and never noticed it was reverse rotation , he put in a standard rotation motor in he called me in because he couldn t start it loll i noticed his error asked him where he put original motor so we could rebuild it . answer scap guy pick up old motor . so now i have a nice merc 260 standard rotation 0 hours in stock he gave it to me and he has a god only knows how many hours reverse rotation motor that i got running for him and he is soooo happy to get his boat back
tazdevil is offline
Old 11-07-2015 | 06:33 AM
buckknekkid's Avatar
Just putting a RR SBC into an old Chris Craft, kept all the originals for reference, bought a new RR cam and seals, etc. It has a 71C behind it
buckknekkid is offline
Old 11-09-2015 | 12:31 AM
http://www.jepistons.com/Images/Tech...pin_offset.jpg
in ref. to post#16 being correct
I'CE is offline
Old 11-28-2015 | 06:28 PM
First off seals: the chain cover and main seal are crank rotation specific. 2nd Camshaft: You'll need to replace the camshaft and tappets with new ones and use special high sulfur lube and remove the dampers on the valve springs during break in There are two methods to turn the cam. It all depends on the cam's distributer helix and lobe configuration. Old school is a 2 gear mesh that spins a standard cam rotation with a reverse firing order. This method is plug and play with the standard distributer gear. Note that only flat tappet camshafts are available unless a custom camshaft is made hence the reason the cam and tappets need to be new. This also means it uses a flat nose cam with the larger bolt circle Dia,. The newer method is to use a chain and sprocket with a reverse cut distributer gear to correct the rotation of the distributer for the oil pump . This method spins the cam reverse rotation with a standard firing order. Generally these are aftermarket cams. The same rules apply to the camshaft as being a flat tappet. There has never been nor will there ever be an off the shelf roller cam for a GM reverse rotation application. Always be very cautious that the camshaft you are using is set up for either the gear set or timing chain set. Also not that Mercruiser/GM made only one flavor of this camshaft. All and every GM RHR small blocks have used the same camshaft in every reverse rotation motor ever made. You can no longer buy the GM camshaft . A stock configuration for the gear set is available through Melling. A cam core is available through Comp Cam and they claim it is a reverse rotation standard firing order camshaft which would have and use the helix for reverse cut distributer gear. I personally had a custom retro fit hydraulic roller camshaft ground from Comp Cams for $850. It uses the gear set with a modified thrust plate and a thrust button in a 5.7 roller block. Lastly I'll clear up the piston orientation. If you use a stock Chevrolet piston it has a .050 wrist pin offset to prevent piston knock when the engine is cold.. It has to be reversed so the notches face the rear of the engine to prevent extreme knock when the engine is cold. Some people will flip the piston on the rods. I chose to reverse the banks so #1 becomes #2 and visa versa and down the line. This corrects the heavy chamfer orientation and also maintains the balance . To each is his own if you feel the need to keep the same piston in the same hole by all means spin the piston around on the rod. Some aftermarket piston do not use an offset so there is no need to change the orientation of the piston. one final note: Some will argue that the Crankshaft is also rotation specific. Maybe back in the hay day when you could get one. Well Today you can't and every modern RHR uses a standard crank. Some will polish the Journals in the opposite rotation. So there it is can you just throw in RHR gear set and camshaft In a LHR? NO you can't
minx163 is offline
