-   -   external hydrualic steering (https://www.offshoreonly.com/forums/do-yourself-boating-budget/330659-external-hydrualic-steering.html)
flashgordon 05-27-2016 08:48 PM
hey ramos.....wow,,,what a project but the end is near,,,both motors in,,,fired the stbd,,got an hr running time on it,,
put in port motor last sunday,,,will fire this weekend
next bleed out hyrd steering system....any advice or tricks there
system is on boat,,,but drive are nor ''talking to each other"""
flash out
time for a captians!!!!
OPIE272 05-28-2016 12:57 AM
I made a hose to bypass the steering actuators. Connected the line between the actuators and turned the steering wheel till all air was purged. That way the lines in the boat were good. Then hooked up the steering actuators.
Turned wheel till it locked out. Cracked the line and bled out the actuator like you do car brakes.
Then checked and topped off fluid level next few times I took it out.
