Backfire Issue, need advice. >
Old 04-20-2016 | 11:02 PM
Originally Posted by sprink58
I'm going to throw some old school logic at you on this.
I would base line the timing at TDC with a static timing light...No1 at TDC and the distributor lighting up on the mark. Fire it up and let it run a bit. Then shut down...set up you timing light and start it making sure you don't see the timing mark wobbling around. Loosen the distributor enough to turn it a bit and bring it up to 8* BFTDC.
I think 14* initial is WAY too much. If this works...figure out what you want to have total advance at 3000 and have a distributor guy set those MSD's up.
I had a similar issue with my Vortecs setting them up and at the end of the day I found broken springs in both my distributors. You didn't mention the history of your distributors but if they aren't new...I would guess that's where your problem is.
You might call the guys at DUI in Memphis and talk to them about this. They have a "Small Top" replacement for the HEI's that might fit your set up. I sent my DUI's I bought on Swap Shop here to them and they set them up.
My Dad and Grand Dad always used to say that if air, fuel and spark all get there at the right time it will run good. Knowing that and 18436572,,,there is an answer to your problem LOL !!
Good Luck !!
roots blown engines like timing at idle.his suonds lazy like not enough initial timing,also sounds like it has a few dead cylinders.
mike tkach is offline
Old 04-20-2016 | 11:07 PM
Ok...roger that on the initial...but something still has me thinking distributors.
Your thoughts?
sprink58 is offline
Old 04-20-2016 | 11:42 PM
hard to say with a 21 second video.i would take the carbs apart and check them out before i started it again.also would check plug wires for resistance.
Old 04-20-2016 | 11:50 PM
hblair's Avatar
The carbs, distributors, wires, and plugs are all new if that helps at all.
hblair is offline
Old 04-20-2016 | 11:51 PM
i watched the video again on a computer with a bigger screen and better sound,timing seems retarted,i would recheck the initial timing as it seems lazy.
Old 04-21-2016 | 12:01 AM
hblair's Avatar
Thanks guys, gonna be hard to sleep tonight now lol
What would you recommend the initial timing be set at?
hblair is offline
Old 04-21-2016 | 05:11 AM
Read thru this thread: http://www.nastyz28.com/forum/archiv...p/t-64065.html
May send you in the right direction....or at least give you some info.
sprink58 is offline
Old 04-21-2016 | 05:52 AM
w/ engine running,look done the carbs,,see if its dumping fuel.sounds like it needs carb work.as for the 14° initial.thats not the problem.I've run blower motors locked out at 32°.
sutphen 30 is offline
Old 04-21-2016 | 08:52 AM
you say you have run locked at 32,and i also used to run locked dist but why do you say 14 initial is not the problem?i believe 14 initial is part of the problem,it needs more.
Old 04-21-2016 | 09:43 AM
hblair's Avatar
I just talked to Ricky at Holley. He said these carbs will never work. He said to get the 0-80592-s blower carbs. Eric from the blower shop recommended quick fuel 650's. In this application, do you guys worry with the carbs being non marine approved carbs?
hblair is offline
